Home > Finance, Insurance & Warranties > Buying Used from Main Dealer vs Independent & Warranty?? |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3747 |
With Approved used from a LR main agent you are in a stronger position due to the higher standards they have to meet - one of which is their Approved used warranty is better and covers most things and if you don’t “feel the love” you can give it back. Yes there are good independents out there but with a main agent you get more clout and if all else fails LR customer service will step in and take a very dim view with black marks against dealers.
20th Apr 2024 9:41pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1469 |
Main dealers will sell Approved Used vehicles up until about 4.5 years old or just outside of original manufacturer warranty.
20th Apr 2024 11:16pm |
That’s not quite correct, LR extended warranties are available to 10 years old and 100k miles, there are two extended warranty types and it is only the Select Extended Warranty that has a limit of £3k - the other doesn’t. Also don’t forget the LR Roadside Assist and Recovery, many aftermarket warranties don’t have that.
21st Apr 2024 6:01am |
smitht2 Member Since: 03 Mar 2016 Location: Yorkshire Posts: 41 |
Thanks for replies. I think the answer to my 2nd question is implied, but to check - is it correct I could only get the LR warranty (the one with cover over £3m) if I buy an approved used car from LR? So I can’t buy from XYZ Indy dealer and then but LR warranty from LR (obvs assuming car is under 100k miles etc)
21st Apr 2024 6:48am |
Yes, you are referring to an Approved Used Warranty - the other is extended warranty.
21st Apr 2024 7:03am |
Thanks again. That point about “being traded out” is very helpful - I was wondering how a £50k+ car ends up outside the dealer network!
21st Apr 2024 7:36am |
Your last point is incorrect. Main dealers purposely don't hold older stock. Most have a policy of "straight to auction" based on age. It's nothing to do with condition of the vehicle - only when under the 5 year mark. Based on the fact the OP is looking at a 2021 vehicle, I would most definitely say stick to main dealer. Use Land Rover's Approved Used website instead of AutoTrader. Some of the main dealers don't use AutoTrader, but their cars will come up on Land Rover's site. 2015 Range Rover Autobiography 4.4 SDV8 |
21st Apr 2024 7:48am |
Consistent clear advice to buy from LR main dealers - thanks.
21st Apr 2024 8:22am |
21st Apr 2024 8:23am |
Steveg Member Since: 06 Apr 2024 Location: Norfolk Posts: 37 |
The most common reason why they end up out of the network is that the RR owners buy other makes of vehicle and trade in their RR. The other make dealer typically doesn’t sell used vehicles of other makes, and so often they will sell it on via auction. Who buys it as auction, is whoever is prepared to buy at the highest price. |
21st Apr 2024 12:41pm |
