![]() | Home > Technical (L322) > Engine running temp / possible overheating |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
AndrewT Member Since: 20 May 2011 Location: Auckland Posts: 97 ![]() ![]() ![]() |
I already had a copy of that. Unless I'm going blind/mad (both entirely possible) it still doesn't show the actual operating temperature range of the engine. |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
Once mine has climbed to the halfway mark mine rarely moves. Reformed |
I couldnt find it either so was going from the top of my head so could be wrong on temps. Dan is an expert in all things RR so hopefully he will pop in to give his 2p worth. |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
I googled for M62 coolant temperature and found this:
Nice find Ric |
Keep in mind the application being described there is the BMW E38, i.e. a 7 series car. It's the same engine but it might have been set up with different target operating characteristics. I'd still advise sorting the issue as the temperature shouldn't shoot around like you described. |
True. Hopefully someone else can confirm the operating temp in a FFRR although I'd be surprised if it was significantly different at partial load due to it being the same basic engine.
Sorry wasnt ment in that way at all. I've lived with this for over 12months thinking mine is about to go bang due to loosing coolant etc. They may be the ranges of the stat but they do seem high as mine for example are a fair bit lower. Look for swast4 (Adam) as I work with him and he has had a HGF and his post rebuild runs round the 98 mark. Look for him on rangerovers.net as he's gone into the cooling system quite a bit for cooling his engine down. I had a quick read of that bumf and can't decide what to think. Granted I've had a few beers. |
Bit more reading for you. http://www.rangerovers.net/forum/viewtopic.php?f=2&t=33023
GKP Member Since: 01 Aug 2009 Location: Hants Posts: 75 ![]() ![]() ![]() |
Change your radiator. Or at the very least remove it for inspection and a clean/flush. Not sure you should be reading this bit. |
Here's my thoughts on what could be happening:
Thanks Dan
Update:
