Home > Technical (L322) > Where does this belong??
robkuijpers
Netherlands
Dear Forum
last weekend I removed the LH inner wheel arch lining to repair my wheel strut. Then one piece of soft rubber (approx 15-20 cm) fell out. I have no clue where that has to be refitted. Any suggestions would be welcomed as I am about to refit the lining soon.
See the picture of the part:
Kind regards Rob 2012 RR Vogue 4.4 TDV8 Sumatra Black
2004 Defender 110 Td5 Epsom Green, 'Alive' Chip tuned and a Warn 8274 Winch
1978 Citroen Mehari Orange Kirghise
2001 Defender 90 Td5 Softop (gone)
1992 RR Classic 300TDi 'Soft dash' Green (gone)
1989 RR Classic V8 Caspian Blue (gone)
Post #690794 17th Apr 2024 5:49pm
D3Jon
I asked the very same question, about a very similar looking item about 4 years ago!
Mine came out of the LH side of my car which is RHD. I never got a definitive answer from any user on here, but I think I worked it out in the end.
See here: https://www.fullfatrr.com/forum/topic56526.html
Yours looks slightly different, not sure if your car is LHD or not? But perhaps it's a different shape to accommodate brake pipes on a LH Drive vehicle?
Regards,
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #690797 17th Apr 2024 6:55pm
garyRR
It's the insulator that tucks into the side of the wing and onto the A pillar? 2015 Range Rover Autobiography 4.4 SDV8
Post #690806 17th Apr 2024 11:11pm
robkuijpers
Netherlands
Thanks D3Jon
The part is still a bit differently shaped. It fell off on the LH side on my LHD model. Is the FBH located also on het LH side of my vehicle?
When the weather gets better, I will again crawl under the vehicle and have another look.
The text I found on the part is:
BH42024578A
>PUR<
R80FA
Although the B may also be an 8. Not the typical LR partnumber though.
@GaryRR, you mean the part the becomes visible in the A pillar when opening the bonnet? No, that's still there. As with D3Jon it fell off when removing the LH wheel arch lining lining.
KR
Post #690812 18th Apr 2024 6:44am
D3Jon
I'd say the differences are between LHD & RHD.
My part number for the similar looking part (but not exact), was BH42-02457-AB
Which is very similar to your's, I'd say it fit's in a similar position to the RHD one, but without the notch out for the FBH pipework.
Just grabbing the images from my older post, mine went here:
2014 Disco 4 HSE
Post #690822 18th Apr 2024 8:47am
robkuijpers
Netherlands
Thanks D3Jon
Sounds logical. Will update this thread as soon as I crawled under my L322.
Cheers
Post #690848 18th Apr 2024 4:02pm
robkuijpers
Netherlands
@D3Jon: is this rubber piece situated behind the wheel arch lining? In other words do I need to remove the lining before I can place the rubber piece back?
Thanks for your advice.
Post #690855 18th Apr 2024 7:30pm
D3Jon
Hi Rob,
Yes it's held in place by the wheel arch liner pressing against it.
That's why it falls out if you remove the liner. I think originally there would have been some adhesive, mine looked like it had the remains of a sticky pad on it.
You would probably get away with releasing a couple of screws / clips and pulling the bottom of the wheel arch liner away to get it into place.
Not sure why yours is different, I presume your brake pipes and fuel pipe are all on that side? Perhaps the FBH is in a different location on a LHD vehicle? I did a quick check with Google but couldn't come up with any info on FBH location variations.
2014 Disco 4 HSE
Post #690922 19th Apr 2024 4:10pm
