Home > Maintenance & Mods (L405) > Does it just pull off.
supershuttle
I've searched and looked in the Wiki but I can't find the answer. I wanted to look and see If I had a secondary battery or a capacitor but unfortunately failed at the first hurdle. I know where it lives but I can't seem to remove the trim panel (offside in boot) does it just pull off. I used a bit of force but it didn't budge, unfortunately I have a habit of breaking things so as I'm sure someone has already done it (removed the panel that is without breaking anything) I just thought I'd better check for any tips or if there's a knack before just resorting to more brute force. Confused Geoff
Post #690781 17th Apr 2024 7:17am
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
It does just pull off but it is quite solid so needs a good pull. It is held in with the usual plastic trim clips so worse case scenario is a couple break and need replacing. I found I managed to get the top part unclipped and then could lever down and pop off the lower part.
Post #690782 17th Apr 2024 7:35am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I start in the middle at the top and get my fingers in and pull down and out that's where other fuses are located. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #690785 17th Apr 2024 8:48am
done this many times when i was researching the stop/start situation.
i found mine to be easier to take off by starting at the top left and working your way to the right.. ... - .- -.
Post #690786 17th Apr 2024 8:51am
It's slotted in at the bottom, so you have to pull the top out like this -
Post #690789 17th Apr 2024 10:31am
