![]() | Home > My Range Rover > How to get started working on my Fattie? |
ssmlr322 Member Since: 05 Mar 2024 Location: Santa Fe, NM Posts: 13 ![]() ![]() |
One other thing: I’m not known for my patience, especially when it comes to mechanical things… 2004 RR HSE 22k miles
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 363 ![]() ![]() ![]() |
Personally I would start with simple servicing work, what needs doing? Oil change is a good one.
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 195 ![]() ![]() ![]() |
That's how I started 3 years ago, download the workshop manual (in the Wiki, top right of the page), there are a lot of guides for various subjects that people have done on their cars. You'll need a good jack that will lift high enough and 3ton axle stands, complete 1/2 inch socket set, spanner set, screw drivers, flat and phillips, fine nosed pliers and then the collection starts to grow, impact wrench and impact sockets, 4 post lift, compressor, more garage space, more tools, more cars, lots of time on Youtube, all good clean fun.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3258 ![]() ![]() ![]() |
Take your time and enjoy it while you’re doing it. Build on what you are learning as you go along.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8538 ![]() ![]() ![]() |
Read the description section, in each section of the workshop manual, it's a rubbish ending (lol) but you will get a good idea how things work, this will help greatly...
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 290 ![]() ![]() ![]() |
As well as advice on here YouTube is your friend for maintenance but find trusted channels like these :
Thank you for all the suggestions. Am following up 2004 RR HSE 22k miles
batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 205 ![]() ![]() |
I'd look at getting yourself a good trolley jack, don't put yourself at risk using the jack that came with the car. I also bought a 3 Tonne jack from SGS and some axle stands.
