![]() | Home > Technical (L322) > White smoke from under car and oil leak |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
So I would check the white smoke isn't in fact from the fuel burning heater, which runs when the engine is cold, to heat the cabin faster. This is behind the left front wheel arch, but the smoke can appear from all kinds of places.
Bazm Member Since: 27 Feb 2024 Location: Lucerne Posts: 23 ![]() ![]() ![]() |
Hi garyRR,
The Webasto burns diesel to heat the cabin whilst the engine is cold, and the exhaust is also behind the wheel arch, so white coloured smoke can appear from it in a number of places.
Thanks. I'm going out today to check it again.
Just by way of update.
Old-un Member Since: 12 Feb 2022 Location: Manchester Posts: 151 ![]() ![]() ![]() |
Are you sure the oil leak problem is not coming from the oil cooler, a common problem with these vehicles. RR owner |
Hello,
Kev the Rev Member Since: 07 Jan 2024 Location: Ripon Posts: 44 ![]() ![]() ![]() |
I totally understand what you're going through. I'm thinking about getting an early L405 and because of all the horror stories I'm sure I'll just be the same, waiting for something to go wrong that will empty my bank account. Sounds like you're worrying too much, let us know what the garage say |
Thanks for the words of reassurance.
Hi Folks,
Further update:
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
Yes, you're correct its condensate from the AC |
Thanks for the confirmation. Much appreciated.
