Home > In Car Electronics (L405) > Software update l405 2014
Looping111
Switzerland 2014 Range Rover Autobiography SDV8 Luxor
LR write on the website, that updates for software are automatic via InControl Touch Pro.. But I think my 2014 is not equiped with this. How can I update ? (VIN: SALGA2JF0EA182934)
Post #689724 2nd Apr 2024 9:42am
you are correct re the OTA updates..
what did you want to update ? ... - .- -.
Post #689726 2nd Apr 2024 10:00am
Looping111
I had tried to change the car configuration with the IID Tool. But I think the tools updated some firmware wrong. After that I had no sound in my car. All entertainment was dead. In the menu I had only the sound setting for the basic sound system, no meridian, no TV, no DVD, no Telephone, no BT no DAB. no NAV. trying to restart by disconnecting Battery not work... All fuses are working, all hardware seems to be working. (Disc drive is booting... but thats all) I think that the software on the ECU of the amplifier or sound system is wrong.. GAP Diagnostic is trying to send me new setups.. but until now no success... I hope today I will get a new config from them. The last one was not working (could not find my IID Tool in case of programming).. I currently lack a bit of confidence to GAP and look for a plan B..
Post #689728 2nd Apr 2024 10:18am
garyRR
As the old adage goes, if it's not broken, don't fix it (which it seems you were trying to update the system?).
Sounds like a failed flash of the firmware, which can be tricky to wipe. If the IID tool can't do it through OBD, it may now need to go to a specialist to be re-coded direct to the device. 2015 Range Rover Autobiography 4.4 SDV8
Post #689852 3rd Apr 2024 10:49pm
