Home > Technical (L322) > Momentary Alternator Fault - should I be afraid?
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
Yesterday a red alert flashed up on the dash indicating an alternator fault (I forget the exact wording). Within a couple of seconds it was gone. This was after a decent motorway run of half hour or so if that's of any relevance. Following fault codes from IID:
P0A1A-87 (40) Generator control module - Bus signal/message failure - missing a message
( on 09-02-2024 15:57:38 at 140318 mi )
B1087-93 (2Cool LIN bus A - Component failure - no operation
No issues on the journey home, but wondering if this points to imminent failure of alternator and/or battery? Alternator is around 3 years old, and new battery 2 years ago.
Any thoughts? Thanks in advance. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #685281 10th Feb 2024 5:43pm
I had similar and it gradually started happening more often and eventually it came on permanently at which point, I replaces the alternator and all was ok, so I would suggest you might be on borrowed time. Got - 2017 SDV8 Autobiography in Loire Blue
Post #685293 10th Feb 2024 8:37pm
RR2B
Thanks alarm_3, not what i wanted to hear! Surely alternator should last longer than 3 years? Fault came up again three times today and cleared almost immediately. Dodgy connection somewhere? 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #685640 14th Feb 2024 5:16pm
RR2B
Update - still getting these pesky codes popping up. After careful monitoring established the following:
1) The fault code only appears after 40 - 45 minutes driving
2) The fault stays up for up to 4 minutes before clearing itself and then randomly reappearing.
3) Voltage prior to fault 14.5V, when fault is up drops instantly to 13.7V, back to 14.5V when fault clears.
As mentioned, alternator was replaced 3 years / 15,000 miles ago. My amateur diagnosis errs towards a dodgy connection - as it heats up, resistance increases to a point where the system assumes a fault. Or a slipping drive belt, expanding and losing tension as it heats up?
Charge voltage of 13.7V does not seem excessively low to me (normal on my TVR), but obviously something is awry.
Indie is keen to fit a new alternator (well, he would be wouldn't he?!).
Thoughts?
Edited to add, KwikFit Bosch battery tester results: voltage 12.75V rated 850, measured 654, IR 3.57mOhms, cranking power 77%, state of charge 87%, cranking voltage 10.62V, load on 14.59V, diode ripple 0.07V 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #689519 31st Mar 2024 3:06pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
it may be as simple as sticking brushes inside, easy to check/fix once youve got the alternator off, the latter being the bulk of the work. Yes it should last a lot more than 15,000 miles. It is also possible as you state to have a broken control wire etc.
The joys of RR ownership Smile
Good luck. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #689554 1st Apr 2024 4:50am
RR2B
Two 90 minute runs over the last couple of days and no fault codes to be seen. Gotta love these self fixing cars! 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #689634 1st Apr 2024 5:23pm
AJGalaxy2012
Like most things in life, if it sounds too good to be true it usually is. The alternator fairy may be having an Easter break Laughing BMW i3 Electric Car
Post #689643 1st Apr 2024 7:22pm
RR2B
As predicted, the fault has returned after the Easter break. Still not dropping below 13.7V when the fault appears, car still running, battery still charging. What could possibly go wrong ...? 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #690357 10th Apr 2024 3:29pm
A lot Big Cry Got - 2017 SDV8 Autobiography in Loire Blue
Post #690371 10th Apr 2024 8:04pm
steve k
United Kingdom 2003 Range Rover HSE Td6 Giverny Green
If your car has any kind of intelligent battery management system used I would look there for the culprit. Voltage dropping to 13.7 every time could indicate that the battery management unit has an intermittent connection to the alternator regulator. When this happens the regulator defaults to 13.7volts which is more than enough to fully charge a 12v battery without damage. Current: 2003 TD6 HSE. 161,000 miles
Previous 1993 Classic 3.9
Post #690387 11th Apr 2024 8:15am
JayGee
Heed the warning signs - get a new alternator Wink 2012 TDV8 Vogue (L322)
Post #690389 11th Apr 2024 8:47am
RR2B
Thanks, makes sense. Any idea where the bms is located? I'll have a poke around in the battery area for any obvious dodgy connections.
JayGee - thanks, if the alternator was original I would not hesitate to get it replaced, but given that it is less than 4 years old (and a 'proper' one was fitted) I am reluctant to go to such an expense until all other avenues are exhausted. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #690394 11th Apr 2024 9:50am
steve k
It will be connected to the battery terminal/s. I'm not familiar with the type used on your model.
You might actually try disconnecting it to see if it flags the same error codes and results in 13.7v at the battery?
If it were me I would do some basic continuity tests between the relevant connections at the battery to the alternator, access to a wiring diagram will tell you what wires and colours etc. Current: 2003 TD6 HSE. 161,000 miles
Post #690395 11th Apr 2024 9:57am
…..but in the end you’ll probably still replace the alternator. My first replacement, that I did myself, as I did with the latter one, in the middle of winter some years ago, “only” lasted 3 years and it was a “proper” one, so it’s all down to fate, not time Thumbs Up
If you have any thoughts on doing it yourself, do it in summer, your hands and arms will thanks you. Got - 2017 SDV8 Autobiography in Loire Blue
Post #690401 11th Apr 2024 12:42pm
RR2B
Update - had a fiddle around with the battery monitor unit connectors, and I've been fault free for over a month now. Thanks steve k for the pointers. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #694094 8th Jun 2024 5:57pm
