Wow. Thank you for this. I've had similar problems and your instructions to reset the MOSTServices and then hit the ID button did the trick. I don't know how you figured this out but I am VERY grateful as I've been through allllll the various other suggestions on the internet and to no avail!
For future reference to others who may benefit from this solution here were my symptoms, which were slightly different than the OP's.
First, we start with the standard BT module conking out: one day my touchscreen wouldn't power past the LR logo and the power button light would blink constantly. I added a fiber optic loop to the BT module and unplugged the wiring harness. This sort of returned the touchscreen functionality...maybe a quarter of the time the LR logo would stay up but I could get into the normal menus with the 'touch screen for 5s, then press SatNav button for 5s' trick. During all of this, my radio worked, sorta. I could change the volume only with the steering wheel rocker and change stations only with the physical button. The Radio page would never show the station data nor would the presets show any values. There was ONE time when the preset buttons actually worked to changed the station but even then there was no station ID.
Also during this time:
The Fuel Mileage page would have no values
The Offroad page would have no values, the suspension graphic did not work, and the wheels did not turn with the steering wheel.
Sat Radio button sometimes appeared and sometimes did not.
Sat Radio, CD, DVD, and Aux soft buttons registered presses but nothing happened.
Date would reset every time the car was turned off
Time would loose several minutes a day (Despite new AGM H8 battery)
SatNav seemed to always work, though!!
