Home > Technical (L322) > I’m in trouble here |
Buellie Member Since: 28 Jan 2024 Location: Essex Posts: 135 |
Has anyone any ideas on this please?
28th Mar 2024 9:27pm |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
You won't get the fittings from the main dealer. The likes of Pierburg do quick connect fuel fittings but you would need to measure and get the correct size also you ideally you need a tool to fit them onto pipes as they need to be pressed into the end squarely although you can DIY with care.
29th Mar 2024 11:33am |
Many thanks Weejock that is very helpful indeed. I have a working fuel gauge now but messed this bit up.
29th Mar 2024 1:02pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1345 |
The typically run along just inside of the sills covered by protective underside plates. V8 or else ... |
29th Mar 2024 3:50pm |
Many thanks Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
29th Mar 2024 4:39pm |
Can anyone explain the routing for this broken pipe please? I’m on laying under the car but cannot see where this pipe goes to. There is a big plastic under tray in front of the rear wheels, would the pipe run under here maybe?
30th Mar 2024 1:54pm |
I am still struggling with this and have a car off the road right now so will really appreciate any help please.
1st Apr 2024 12:58pm |
Anyone please? Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
2nd Apr 2024 9:17pm |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 532 |
Hi, have you considered whether you need to replace this pipework at all ?
2nd Apr 2024 9:32pm |
Thanks, but the easiest way would I think, be to replace as it is. I am trying to establish where the broken pipe goes to. I can the remove the other end and see what pipe I actually need. The quick connect part has snapped off the pump end and I just need to get it moving again. Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
2nd Apr 2024 9:42pm |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 329 |
A Google search throws up some options including
3rd Apr 2024 4:21am |
Thanks that is really helpful Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
3rd Apr 2024 4:50am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
Did you successfully retrieve the end of the fitting that broke off ? .
3rd Apr 2024 1:31pm |
Yes I have that Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
3rd Apr 2024 1:58pm |
