Home > Maintenance & Mods (L322) > Add a second battery in parallel?
Harvenberg
Sweden 2011 Range Rover Autobiography TDV8 Nara Bronze
Could I add a second battery in parallel in the boot? I just want to increase the total ah of the system to be able to runt the FBH more often. Of course with the appropriate fuses on the plus side.
Post #689331 29th Mar 2024 4:20pm
Dolphinboy
There are lots of 'how to do it' on here. do a search using the key word 'second battery'. I would also look in the wiki (top right of this page).
It's worth doing if you have cold temps but make sure it its done properly or it can lead to another drain on your main battery.
Good luck! Thumbs Up
Post #689339 29th Mar 2024 5:21pm
Harvenberg
Thanks!!
Post #689341 29th Mar 2024 5:31pm
