Home > Maintenance & Mods (L322) > Costco engine oil (2009 facelift, 3.6 TDV8) |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1464 |
They don't sound like especially good deals.
26th Mar 2024 9:43pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3196 |
Agree with Gary - nothing good about those prices. On a 3.6 you can't realy go wrong with an oil as long as it's the right viscosity grade as there is no DPF to worry about for. Just make sure you change it at intervals at least way shorter than the official service interval. 2012 TDV8 Vogue (L322) |
27th Mar 2024 7:21am |
rryan Member Since: 17 Feb 2024 Location: New Forest Posts: 31 |
Thank you both, really helpful inputs as always. I’ll get ordering 2009 facelift L322 3.6 TDV8 - Buckingham Blue |
27th Mar 2024 8:15am |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 731 |
The problem with using any lubricant other than that specified by LR is that you (or probably the next owner) wont know that it wasn't good enough until it is too late.
27th Mar 2024 10:13am |
Not quite true.
27th Mar 2024 11:52am |
I think we're probably in agreement, when I said specified I was thinking of the various specifications and not the brands. I don't know enough about the what the specs mean to be able to separate the important bits from the marketing Bull so I make sure that I get an exact match (usually Smith & Allan).
28th Mar 2024 10:58am |
These posts were definitely a good read and informative, cheers both. I was never intending to go with the cheapest parts but was looking for easily accessible, meaning I could grab replacements anytime as opposed to have to dig or wait for them.
28th Mar 2024 11:11am |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 |
Vacuum pump failure due to oil deposits leading to a loss of assistance? Cannot see how there could be a total failure hydraulically due to wrong engine oil, so would have to be an assistance failure, unless the braking system had been designed non-compliant with type approval legislation. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica. Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500 Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten! |
28th Mar 2024 11:37am |
"Vacuum pump failure due to oil deposits leading to a loss of assistance?" Spot on, you're right the brakes didn't actually fail but they didn't do what the driver expected them to do when she put her foot on the pedal so the perception was that they had failed.
28th Mar 2024 5:07pm |
How long ago was that? Sounds like the 'sludge' issue that plagued cars in the 90's 2012 TDV8 Vogue (L322) |
28th Mar 2024 6:33pm |
Yes, it even looked like said issue but it was a 14 plate car and it wasn't that old at the time so I'm guessing 2019 ish. |
29th Mar 2024 4:24pm |
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 101 |
When an oil blender states
then I would like to see the base oil listed in the SDS, with CAS number. And it isn't. Only the anti oxidant additive is listed, Bis-(nonylphenyl)amine, CAS 36878-20-3 The rest of the specs look ok and nowadays they can be easily reached by using Group III base stocks that are not truly synthetic. The one and only way to show if an oil performs as good as you think it does is to have it analyzed, iow do a Used Oil Analysis (UOA), that will show, among others, viscosity after using it, fuel dilution, wear metals (always good for a nice debate) and leftover TBN. 2012 4.4TDV8 2000 Honda S2000 |
6th Apr 2024 8:37am |
