Home > In Car Electronics (L405) > Reset or reboot Meridian Soundsystem
Looping111
Switzerland 2014 Range Rover Autobiography SDV8 Luxor
After changing at the. Config of my RR14, the soundsystem,nav, tv, tel…all is dead .. or deactivated.
Is there a procedure to restart? (Fuses are OK, Battery disconnect no success…( I disconnect the Battery under the spare- wheel..)or must I disconnect the Battery trunk right side??
Does. Everybody know a procedure to re initialisize or reset the system?
BR
markus
Post #689098 27th Mar 2024 12:08am
Kot
I presume you have checked the fuses for your sound system/amp etc?
In my MY18, I have had to pull Fuse Link 16 (FL16) off side boot panel, and wait a few minutes then replace it, this is NOT the normal fuse F16 you can see all in a row at the bottom.
But yours is MY14 pre facelift, so it could be a completely different fuse link. Look in the WSM in the Wiki to confirm. 2018 SE SDV8 4.4 Byron Blue
Post #689108 27th Mar 2024 9:39am
Did you use an IID to change the configuration file...?
If you did you can return the file to what it was when you first plugged the IID in... Thumbs Up Pete
Post #689111 27th Mar 2024 10:09am
Looping111
Yes, I've tried to use the backub fom IID Tool.. But no success.. But I will check the wiring diagram and check the system.
Maybe it could be possible that my chinese carplay adapter could be responsible, because I had some error codes in the NAV System... I will disconnect and will see what happend... Can I expect a reply from GAP Diagnostics? I've sent them a email as well...
THX Markus
Post #689118 27th Mar 2024 10:37am
