Home > Technical (L322) > Car cranks no start
Triumph72
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
Car cranks no start
Hi, any advice is appreciated, I Fixed a fault with my EGR valve about a month ago, the car has not been used much since then but was running fine, I decided to get the car ready for its mot and it started fine.
I left it running for about 2 minutes when it stopped suddenly and will not restart, codes were checked and nothing came up on the IID. I tried another code reader and came up with P0191 - 23.
The car has plenty of diesel, fuel comes out of the Shrader valve at top of engine the filter was replaced about 1000 miles ago, the battery is good
I opened one of the injector fuel rail pipes and have no fuel there does anyone have any advice on what to try next?
TDV8
Post #687173 4th Mar 2024 4:06pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
There are two fuel pumps one is in the tank under the rear seat I'm not sure about the other one, the Main culprit is the one under the seat. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #687232 5th Mar 2024 12:12am
Triumph72
Eventually got it started after fitting a High-pressure fuel pump, not a difficult job to do, but the pump was expensive. it is fitted at front of engine
Post #689087 26th Mar 2024 8:44pm
