Home > Maintenance & Mods (L322) > Iid please help |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35377 |
withe a iidtool you can revert to the settings before any adjustments....or leave for an hour and see. ... - .- -.
26th Mar 2024 5:00pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3776 |
Yes you can Stan if it’s a 2011 4.4 tdV8 ?
26th Mar 2024 5:11pm |
my bad mike.. ... - .- -.
26th Mar 2024 5:13pm |
Buellie Member Since: 28 Jan 2024 Location: Essex Posts: 140 |
Thanks, all cleared now but no digital speedo Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
26th Mar 2024 5:15pm |
how to from the wiki,
26th Mar 2024 5:18pm |
From memory it’s in the body control module BCM, something like activate 2nd speedo.
On holiday from work, new car, new iid tool, complete idiot, what can possibly go wrong 😂 Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
26th Mar 2024 5:19pm |
The good thing about this forum, you can always rely on Pete
26th Mar 2024 5:21pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3255 |
Anytime you change something in the CCF it will throw a set of warnings and system failures. You just shut down, lock and unlock the car and it will be fine. You will also see the clock resets as do windows , date, etc which is anhoying. 2012 TDV8 Vogue (L322) |
26th Mar 2024 5:55pm |
Many thanks for that info Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
26th Mar 2024 6:41pm |
Many Thanks Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
26th Mar 2024 6:42pm |
Thanks Stan I did read and follow that. The last bit is not so clear, do you know what I have to select for the digital speedo? I selected second display units same as trip meter Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
26th Mar 2024 6:46pm |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 212 |
Are you not supposed to just have the ignition on to edit the CCF? |
26th Mar 2024 7:03pm |
The GAP site has a very comprehensive FAQ in addition to the user manual where 99% of issues or questions can be resolved. Anything unusual that can't be found and emails to the team are usualy answered very quickly. 2012 TDV8 Vogue (L322) |
26th Mar 2024 7:15pm |
