![]() | Home > Technical (L322) > Brake pad falling off |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2567 ![]() ![]() ![]() |
Has the bearing moved?
Leigh4571 Member Since: 09 Oct 2021 Location: Shropshire Posts: 19 ![]() ![]() |
Not that I can tell, no wobble in hub, gap from guard small and hand brake works fine.
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 284 ![]() ![]() ![]() |
Are the calliper sliders siezed? |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 490 ![]() ![]() |
This needs a picture please, because unless the caliper carrier has snapped / broken, as I see it, it's impossible to lose a rear pad - unless the wrong pads have been fitted.
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 282 ![]() ![]() ![]() |
I’d suggest a thorough check of the whole system; my understanding is that there’s a split braking system design which partitions the master cylinder reservoir so that the front brakes remain operative should the rears fail and visa versa. If your experience was a “total loss of fluid and zero brakes” the implication is that something has mistakenly been done with the brake lines to negate this protection. TDV8 4.4 2012 |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 890 ![]() ![]() ![]() |
Here are the OP’s photos.
Have you got the brake pad that fell off, if so is there any pad material on it. |
How can the pad 'fall off' when there is a caliper attached???? 2012 TDV8 Vogue (L322) |
I don't have the missing pad but all the rest are 6mm give or take.
According to my parts guy;
That there is your problem then. You've solved this yourself. |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 526 ![]() ![]() ![]() |
I ordered some rear discs from auto doc, correct part number etc but they sent the solid discs which are smaller too.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1595 ![]() ![]() ![]() |
………. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
Hi All,
