Home > Technical (L322) > B12E8-23 Liftgate/tailgate control release switch
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
B12E8-23 (2F) Liftgate/tailgate control release switch - General signal failure - signal stays low.
I assume this is more likely to be a broken wire somewhere rather than a problem with the button.
Any suggestions on where to start looking? Or information on the wire colours, etc. to look for?
Thanks.
Post #687550 8th Mar 2024 3:55pm
Mike Edwards
Any thoughts?
Post #688962 25th Mar 2024 4:18pm
ballast
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Does the tailgate not release then? I assume you mean the upper? Does the key release it?
Post #688995 25th Mar 2024 9:50pm
Mike Edwards
The button on the top of the lower tailgate has suddenly started to misbehave. It does open sometimes, usually after a bit of jiggling around.
Post #689004 25th Mar 2024 10:47pm
