Home > Technical (L322) > Disappearing 'P' causing non start issues
pdt
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Hi gs
Did a quick search but did not find anything...
So, we went away for a few weeks and have just come back to a MY06 s/c that wouldn't start.
I had a mate looking after it and he had started it a few times while I was away - until late last week it wouldn't play the game.
Got back today and had the AA man out to check battery.
What we found was that the gear selector 'loses' park - ie it doesn't show up on the dash. A push of the stick to the front of the car and it magically appears on the dash. (the 'P')
Obviously we can start in neutral - but thats not the point!
Anyone else had these issues?
Easy fix? Will it go away with more use?
Cheers
pet
Post #68900 16th Jun 2011 11:16pm
Does the gearbox actually go into PARK - e.g. holds the car on a slope? .
Post #68901 16th Jun 2011 11:30pm
pdt
Yep.
I think it is engaging park and the other gears.
Just noticed today however some 'not going into gear after turning a sharp corner'
Wondering if this is related?
Could it be a time to change gearbox oil?
Cheers
pdt
Post #69038 17th Jun 2011 5:15pm
Did you see my recent post re spraying WD40 on the Gear Selection Lever Linkage Assembly on the side of the gearbox?
Just get under car and you will see it and they are very prone to getting corroded and causing gear selection problems and loss of drive etc...
http://www.fullfatrr.com/forum/topic6333.html
This may well help. Thumbs Up
PS: In the WIKI under Known problems too....
Post #69041 17th Jun 2011 5:33pm
pdt
Thanks Gaz
Smile
Post #69060 17th Jun 2011 7:29pm
pdt
A report back on this.
Hats off to WD40 - and of course Gazelio for the advice.
Completely solved the problem in under 5 minutes.
I urge everyone to have a look at this linkage and get it protected.
I thought is it was going to be expensive!!!
cheers
pdt
Post #69877 24th Jun 2011 8:14pm
I too urge everybody to spray lubricate the gear linkage next to the gearbox - its a MUST DO and solves many present and future gearbox problems.... Thumbs Up
Post #69879 24th Jun 2011 8:50pm
