Home > For Sale & Wanted > [For Sale] Complete Spare/2nd Key- Flip Style
Have you only got one key for your vehicle? Can you risk losing it and not having a key at all?
I can now supply you with a full and complete new spare key, as per the photos below.
This is ready to be coded to your car either by yourself with an appropriate IID type tool, or by your local garage.
These are UK spec 433mhz. They have a blank blade ready to be cut and matched to your single key by your local locksmith (I wouldn’t recommend Timpsons).
Yes you can buy these cheap on eBay (Or very expensive at your Dealer), but these are high quality with a brand new genuine Panasonic VL2330 rechargeable battery in place. The cheaper eBay versions have an incorrect battery.
You’ll see the key shell has a tiny screw ‘allowing’ it to come apart- These were NEVER designed by Land Rover to be taken apart and there should be no need to, the new battery will outlast your vehicle.
I would prefer to supply these bonded shut (as per all the keys I have done and as per your original Land Rover key). This adds strength and waterproofs it. If you would prefer it was not bonded I can do this.
Price is £50 inc 1st Class Signed for and tracked postage.
I can send internationally, please PM for added postage cost (dependent on country)
PM me for details
Photos below
 Discovery 4 HSE
Post #687339 6th Mar 2024 1:02pm
AlexLRV8
United Kingdom 2008 Range Rover Vogue TDV8 Zambezi Silver
Can you guarantee this will work on an 06-09 l322? I bought one off eBay for about £40 but my Gap iid was unable to code it. It too had a screw in the side and was sold as 433mhz for 06-09 l322.
Thanks,
Alex
Post #688866 24th Mar 2024 12:12pm
I’m afraid it won’t.
After much research recently it turns out that the L322 in that date range were not codable by external tools.
I’ve read many threads all about it. It’s extremely frustrating. Discovery 4 HSE
Post #688874 24th Mar 2024 1:30pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
Hi
Mine is a 58 plate so should be able to coded …..yes .?
Thanks
Post #689857 4th Apr 2024 5:29am
Just to add to this, we have been messaging on PMs about this and will308f seems to think a 58 plate car (2008) can have a replacement key programmed, so we might be trying this out to see.
Watch this space. Discovery 4 HSE
Post #689971 5th Apr 2024 7:44am
will308f
hi
just been looking at the key blade and i believe its the wrong one (its to thin) it should be wider ....or is it just the way the photo was taken ?
Post #690038 6th Apr 2024 6:05am
There are two types and I have both.
You’re correct that the RR had the wider blade. Everything else is the same. Discovery 4 HSE
Post #690041 6th Apr 2024 7:41am
will308f
hi
is this keyfob a genuine one ?
Post #690155 7th Apr 2024 1:39pm
will308f
hi
ok so after trying to reprogram a key fob (which failed),i got in touch with gap and believe i have got to the bottom of things .yes you can add more keys using the gap tool -however you have to use a genuine range rover key fob and they say it has to be a new one and not a used one and you will need a working key to start with as well (if you dont have any working keys then it will have to be a dealer job) ....these cheap ones from ebay or other websites wont work .the cheapest place i could find for a genuine key fob was £140 now my local lock smith only charges £120 (had a new from him last year).so unless someone can find a cheap one from somewhere and they get it to work then great and pass the info on .............but i would be happy to be proved other wise Thumbs Up
Post #690245 8th Apr 2024 2:19pm
Thanks for the updates, it's what I understood from GAP too.
It's such a shame and quite odd that LR did this to this model and year band. Quite frustrating for all concerned. Discovery 4 HSE
Post #690717 16th Apr 2024 8:55am
will308f
yea i know god knows why they decided to do it ,however i dont like to be beaten so think i may keep trying .my biggest problem i am having is that i cant turn the key in the barrel all the time it only turns every now and again (poss a transponder issue) so i get timed out you only get 30 seconds .... Censored
Post #690739 16th Apr 2024 2:04pm
A Social Media Request
Hi everyone,
Thank you to everyone who has used this service and those who have left feedback here on the forum over the years, it is very much appreciated.
I've set up an Instagram account specifically around the key service- I'm not sure what to do with it right now but if you have a spare 30 seconds could you follow it and like a post or two?
Getting any sort of traction on a brand new IG account is very slow and difficult so all help appreciated.
The account is @rruk_lr_key
Many thanks Discovery 4 HSE
Post #691075 22nd Apr 2024 9:00am
Don't forget to like and follow my Instagram account if you have a spare moment Bow down
rruk_lr_key
Post #692291 10th May 2024 9:08am
