Home > Maintenance & Mods (L322) > Condensation in rear light cluster |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2553 |
Have you re-checked your join reseal? I used glue rather than sealant because the clear was coming adrift right along the inside edge. |
21st Jan 2024 12:06pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
Will check when I take it off again to dry it out 2012 TDV8 Vogue (L322) |
21st Jan 2024 1:04pm |
Marzipan Member Since: 02 Apr 2020 Location: North West Posts: 23 |
Hi, I've had lots of help from others on this site so I thought I would share my blunder which hopefully will prevent you from making the same mistake. I had condensation in the back lights and I used methylated spirit on the lens after drilling a small hole in the bottom of the light unit and the light cracked - oops. Good luck with your fix. |
20th Mar 2024 9:12pm |
