Home > Maintenance & Mods (L322) > Suspension went mad - then bad.... |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4311 |
Do the bag only and save some dosh 💰 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
18th Mar 2024 7:31pm |
Paul H Member Since: 17 Oct 2023 Location: coventry Posts: 69 |
I would replace the struts and bags, they are 'relatively' cheap for the fronts from Aerosus and they discount if you order a pair. Delivery is 48hrs and when I was looking they were around half the price of anywhere in the UK! 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea! |
19th Mar 2024 8:55am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
Just ordered 2 x Aerosus front struts. Weighed up all the options including replacing bags to existing struts either by myself or a garage but DIY strut replacement was the quickest and easiest solution. Will do the rears ( bags and struts ) in the near future. Ever since I've had it I've had that nagging insecurity that a bag could let go and leave me imobilised. 2012 TDV8 Vogue (L322) |
19th Mar 2024 10:12am |
Aerosus front struts arrived today which is super fast service. The material on the bags looks a bit flimsy but they don't have to last 12 years like the existing ones. Also ordered rear Dunlop bags and Bilstein shocks for the rear as may as well do the whole lot. Also ordered a proper 3 tonne jack from SGS and some beefier axle stands so I can work with confidence. 2012 TDV8 Vogue (L322) |
20th Mar 2024 6:05pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 |
Good luck getting the knuckle bolts out, they usually take a bit of persuading to say the least 😳👍 |
20th Mar 2024 6:09pm |
I'm up for a fight! 2012 TDV8 Vogue (L322) |
20th Mar 2024 6:13pm |
RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 79 |
interested to hear what the performance is like vs OEM airbags |
20th Mar 2024 7:42pm |
Not sure how I'd measure 'performance' I'd assume the spring rate of the air bags is similar and that a new shock is better that one with 170k miles on it. 2012 TDV8 Vogue (L322) |
20th Mar 2024 7:56pm |
Front struts changed and much easier than expected. Took an hour each side working alone and the big pinch bolts surrendered to the Ryobi 400Nm impact wrench without a fight. Used a jack under the hub to ease the strut up rather than trying to hold it up with one hand and reach over for the studs with the other. Reused the old airline fittings with a smear of silicone grease but not entierly convinced by these connections so I'm leaving the rear bags and shocks until tomorrow to see if it's held up overnight. Reckon I was very lucky to make it back home last week as the front dropped very quickly after moving to to my office carpark today to do the work. Originals were dated dec 2011
23rd Mar 2024 1:13pm |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 468 |
I'd say after 170K miles you've made the right decision to change the entire strut. Sounds like you'll be driving along safely smoothly with new suspension all round! J 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
23rd Mar 2024 2:08pm |
No drop overnight so on with the rears. 2012 TDV8 Vogue (L322) |
24th Mar 2024 8:22am |
when I replaced the fronts on mine with Aerosus I was pleasantly surprised at how quickly and easily they fitted and the quality.
24th Mar 2024 8:24am |
Changing the rear shocks was very easy. Old ones seemed as stiff as the new ones when pressing both down together so likley they would have been fine left alone. The rear bags looked in good condition and didn't have visible deterioration of the rubber so left them alone. Just driven a few miles localy and to be honest I can't realy feel any difference. Feels nice having confidence in the air suspension at long last. 2012 TDV8 Vogue (L322) |
24th Mar 2024 2:16pm |
Removed the bags from the struts and no leakage of oil inside so reckon they would have been reusable so keeping them just in case the Aerosus ones have issues...
29th Mar 2024 3:06pm |
