Home > Technical (L405) > various not available
garyL
United Kingdom 2017 Range Rover SVAutobiography 5.0 SC V8 Balmoral Blue
hi,
i have this re-occuring problem on my 2017 L405. It randomly displays that all the following are not available, Emergency brake assist, HDC, ATPC, stability control, AEB, forwartd alert. i've read about dirty, misaligned radars, dirty windscreen blocking cameras etc, it does it irrespective of how clean/dirty it is, (though still not sure if cameras, radar or both control these systems ) The strange part is , if i shut off and restart ( even without moving) the fault is gone. It very rarely returns once moving but has done on a couple of occassions. I'm assuming that by restarting i'm resetting the software and thats why it clears ?. If something is dirty, misaligned, faulty, how would just restarting clear it ?? The battery is brand new. Anyone else had similar. Any advice appreciated- thanks
Post #688498 20th Mar 2024 10:01am
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Have you checked earthing point in front wheel well, thats normally were spurious issues start to originate from, best to check and quite easy and a quick fix. search earthing point. you will see my issues plus others. Thumbs Up
Post #688529 20th Mar 2024 7:34pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I had a similar problem recently, though mine went into those faults all the time.
The code reader came up with lots of faults, but the most significant was rear right ABS sensor. So I bought a new ABS sensor from JLR (having been advised only to go for genuine parts due to random problems that can occur from non genuine ones).
When I came to start to remove the old sensor, I saw this...
This is the plug from the main wiring loom that connects to the ABS sensor, and if you look closely one of the wires is broken (the green is the corrosion on the copper where it has been flexing and eventually broke). All very well, but how to access the plug to do anything about it. I ended up cutting the other wire, disassembling the plug...
Then soldering new wires into the plug before soldering the new wires to the wiring loom with lots of heatshrink.
Cleared the faults and the problem has been fixed - all for the cost of £0 and a few hours. I wonder if one of your plugs is going the same way and connecting intermittently? Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #688685 22nd Mar 2024 9:21am
D3Jon
Very tidy job Zebedee Thumbs Up 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #688686 22nd Mar 2024 9:26am
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Did you check the 12v auxiliary battery?
Post #688719 22nd Mar 2024 12:17pm
garyL
i was under the impression the 2017 models didnt have an auxiliary battery, that these were replaced by something else ?
Post #688721 22nd Mar 2024 12:25pm
