![]() | Home > Technical (L405) > Difference on the 5 litre petrol engines |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 490 ![]() ![]() |
Hi,
Bluebird Member Since: 30 Aug 2021 Location: Cardiff Posts: 98 ![]() ![]() ![]() |
Thanks Jon , plenty of information you supplied - appreciated. Tim |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 601 ![]() ![]() ![]() |
I'd go SVA .... |
Rex the RR Member Since: 15 Nov 2019 Location: Perthshire Posts: 43 ![]() ![]() ![]() |
Just been through the same scenario. Hell bent on getting an sv. Ended up buying a p525 ab. Wanted a cream interior and blue exterior but the sv seats are all black trimmed, not a good look. |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 238 ![]() ![]() ![]() |
I would go for the one I could afford with the best service history, then spend $2,000 on a remap from www.velocityap.com and have 605hp.
Thanks for info all. As I am trying to avoid too many oil changes - I should look into if there is more service requirements for the SC. |
JLR oil change schedule has been the same on all the petrol engines I've had right from the BMW era. Once a year or 16k miles whichever comes sooner. Some prefer to do it more often, but that's not the official schedule. Its not like the oil burners with dilution issues etc. I no longer do the miles, but the car tells me when it wants to see Craig at the beginning of the year.
Thanks Mike for the information. In error when I bought the diesel RR I never thought their would be issues with short journeys as this never happened with my previous bmw. I think it was miss selling as the dealer knew I was retired and going to mostly short journeys. So that why I will try to ask questions on this great forum, before buying. |
I've been monitoring soot build up in the DPF of our 2.0L XC90 and it rises *far* faster than it ever did in our 4.4TDV8. It can go up 6% in 14 miles of country road driving (our school run), which is a staggering amount. Luckily it also does a 120 mile return motorway run once a week when the wife goes into the office.
That's a gorgeous interior ![]() Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1393 ![]() ![]() ![]() |
If you are almost only doing short journeys might the P400 PHEV be suitable? Have a look at the Harry's Garage videos on that 405, which seemed to work well, and also economically for him (he does have his own charger which will make a big difference). It is what JLR recommend for people doing mainly short journeys, see the "which is right for you" guide on the LR UK website.
Thanks for information. Electric charging cars are a mystery to me, but i like Harry YouTube videos and will have a look again. |
??? Oil change/service $350 CAD New engine $25,000+ CAD Why are you buying a Range Rover? It is going to require maintenance. Much more than you think. Oil changes are the cheapest thing. I had three door latches go bad. $800 CAD, each. Alternator went bad due to RH valve cover leak into it, $5,000 CAD. Rear main seal, $1,500 CAD. Brakes at all four corners with my labour, $1,500 CAD. Engine mounts with my labour, $600 CAD. Buy the best warranty you can or buy something else. Dan. π¨π¦ 2013 L405 5.0 SCV8 |
Thanks I only buy from a main dealer as I want the comfort of a Land Rover full warranty. |
