![]() | Home > Maintenance & Mods (L322) > MPG: 4.4 Diesel VS 4.2 S/C |
Crispian22 Member Since: 25 May 2017 Location: Midlands Posts: 144 ![]() ![]() ![]() |
I'm on my 2nd 4.2 and mid to late teens is all you can expect.
RogueRanger Member Since: 03 Jan 2024 Location: Kent Posts: 116 ![]() ![]() ![]() |
My 4.2sc averages16-17 mpg if I use it locally. That’s doing say 5-6 mile runs along small country roads and lanes and not spending a long time standing in traffic. Hope that helps. Des
Best way to run into DPF issues is using a diesel for short daily runs and a low anunal mileage. You probably won't even save on fuel costs doing 4k miles per year. 2012 TDV8 Vogue (L322) |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 189 ![]() ![]() ![]() |
I live in the country side, if I go to town its about 6km and if I go to the next town over its about 20km. I do these a few times a week and for the most part I cruise and enjoy the ride but having a 4.4 that for some reason this week is very peppy after some work I do like to over take the slow cars and bring the revs up. my clock says 10.5-11.5L/100KM. On a longer journey Ill get 9.5L/!100KM. This may be down to callipers that need a service.
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
4000 miles per annum! 4.2 SC every time. Previous cars:
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
For a 4Kpa and mostly short run use case, a modern diesel would be the less sensible choice.
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 504 ![]() ![]() ![]() |
Bought my 07' 4.2 in 2015.
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 512 ![]() ![]() |
By my quick reckoning, the petrol S/C will cost you about £500 / yr more in fuel for the 4K annual miles you mention. Based on today's fuel prices and assuming you're happy to put normal 95 RON in it.
RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 79 ![]() ![]() ![]() |
I would go petrol for short journeys of and 4k per year, the Diesel takes a while to heat up so worse MPG. I get an indicated 25-30mpg on a 15 mile countryside commute, and 35 on long motorway trips (they usually overread and I haven't calculated it, guess it would be 5% over)
I’m not aware that the supercharger or timing chain have any issues on the 4.2sc. According to the forums, it’s one of the most robust and reliable engines in any L322. And you can get a 4.2sc for £300pa less road tax which if you’re only doing 4k miles pa makes a big difference to overall running costs. Des 2005 (2006 MY) L322 4.2sc Java Black, 2010 facelift conversion 1965 Lenham Lemans GT 1310 , Gulf Racing blue, FIA spec and road legal 2018 F56 Mini JCW, Thunder Grey/Black, Mulgari St2 tuned, FMIC, short shifter and Eibach springs |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
I drive the 4.4 diesel... it's plenty fast enough for a car of this bulk... the handling outweighs any sporting performance you might like to have in reserves. its nice to have immense power reserves to show it off etc... but the reality is, it comes at a cost. the 4.4 tdv8 its such a refined diesel you hardly hear it. but one thing not yet mentioned.... is the ULEZ type charges to enter certain cities/areas. that to me is the only drawback. and I live in one! I don't use mine everyday, and now save up errands to do on a paying day...so I pay less overall. the 4.4 tdv8 is the most frugal l322. -and what a drive!! |
I did caveat the timing chain comment with the fact this applies to the 5.0 Engine. I fully agree, the 4.2 isn't known for premature timing chain or tensioner wear issues. I thought the front pulley (nose) bearings often need changing in the 4.2's SC once mileage goes North of 100K? Also the isolator's spring can be prone to breaking? All cheap enough to fix though! ![]() Not knocking the supercharged engines in any way, or the 4.4 TDV8 for that matter (it's a cracker). I was pointing out the advantages of the petrol over the diesel if used for short journeys, but balancing it with the small disadvantages of the petrol SC engine, over and above the obvious thirst of the petrol SC. Cheaper road tax is a very good shout out! ![]() Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1481 ![]() ![]() |
Short trips and low mileage, I'd go for the petrol. You're asking for DPF problems with the diesel. 4.4L of capacity idling away very quickly accumulates the soot content.
PDC Member Since: 02 Oct 2018 Location: Warwickshire Posts: 75 ![]() ![]() ![]() |
I'm biased, but I would go for the petrol. On a run I can get 22ish but stop start around town traffic and I will be lucky to get into double digits.
