![]() | Home > Maintenance & Mods (L322) > Oil mist debris on radiator |
It’s common on the 3.6 for the hoses from intercooler to intakes to split so get these replaced ASAP as leaking intake charge can cause the turbo’s to overspin as they try to compensate for the loss of pressure. 2012 TDV8 Vogue (L322) |
olavfo Member Since: 05 Oct 2022 Location: Norway Posts: 4 ![]() ![]() ![]() |
Thank you, I will definitely check them for a leak and order new ones. But, why the oil? Shouldn't the intake charge be clean as a whistle? |
All turbo cars leak some oil vapour from the compressor seals. 2012 TDV8 Vogue (L322) |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 185 ![]() ![]() ![]() |
I just changed the intercooler hoses on my FF 3.6 TDV8, the old ones did have a smear of oil on the inside, as JayGee says, some oil is nothing unusual after quite a few years of use. |
