Home > Maintenance & Mods (L322) > Resonance Noise from front left area after service |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3161 |
funny I have exactly the same thing. Had a front near side lower arm replaced and now there is definitely more noise from the pax footwell. can't work out why yet........... |
19th Mar 2024 8:51pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3236 |
The splash shield for the gearbox is the usual culprit for metalic resonance noises at low revs. Remove and remount after bending it a bit or put some damping sheet between it and the bracing 'X' part under it. 2012 TDV8 Vogue (L322) |
20th Mar 2024 7:56am |
CharlieF322 Member Since: 19 Mar 2024 Location: Essex Posts: 16 |
Thank you! Will have a go this weekend 👍🏻 |
20th Mar 2024 8:05am |
