Home > Technical (L405) > Oil level not available P250B-37
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Hi
I have the dreaded oil level not available fault (P250B-37). I have had the oil level sensor replaced with a new genuine one. The garage has applied power to the oil level sensor and it works fine. I have also had the service bulletin N375 applied but I am still getting the fault code. Anyone got a clue as to what to try next?
TIA
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #688394 19th Mar 2024 10:56am
caymanblack
Could it be the sensor wires in the sump burnt out? I have oil in the sensor plug which I will get checked out very soon but my oil reading is fine, and apparently, the N375 modification has been done. overfinch modified
Post #688502 20th Mar 2024 11:44am
IGP
Hi
Thanks for the response. Unfortunately I think the wires in the sump are OK as when power is applied directly to the plug in the sump (so I have been told by my garage) it al works OK.
Regards
Post #688504 20th Mar 2024 11:53am
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
when I had the oil sensor replaced on my car I was first told by the garage that the problem was still not fixed. After authorising an additional 2 hrs of labour for diagnostics they came back to me and stated that a fuse had also blown, most likely as a result of the failed sensor, and after replacing it everything worked fine. Now, I know this wont be much help to you but I dont know which fuse they actually had to replace but I think the sensor is on the same connection as something else so it is not obvious but maybe a pointer of somewhere else to look?
Post #688506 20th Mar 2024 12:50pm
Fifth Horseman
Scotland 2018 Range Rover Vogue SE SDV8 Carpathian Grey
It should be fuse F8 (15A/Blue) in the engine bay fuse box marked Engine Management System, (on post 2017 models its F24 - 15A)
Post #688511 20th Mar 2024 2:20pm
IGP
Thanks guys, already checked that fuse. I fact I replied to ReggieMac's post on the LRUk Forums. If you follow the wiring diagram you can see the oil sensor on F8 event though it makes no mention of it in the manual. Am getting contact details for someone who only works on Range Rovers so will keep you posted.
Thanks
Post #688516 20th Mar 2024 3:14pm
EOD Steve
United Kingdom 2012 Range Rover Vogue TDV8 Sumatra Black
You could try what the hack is to fix this on the L322...
I did this yesterday...
1. Open bonnet
2. Access service menu (ignition on, engine off)
3. Access where is says OIL LEVEL NOT AVAILABLE
4. Press the cruise control CANCEL button TWICE
This will then reset the indicator to whatever reading is for the oil within your engine.
But maybe this isn't the same for the 405?
Worth a try I guess.....
Steve 4.4 TDV8 Sumatra Black + Ivory Leather
Post #688663 21st Mar 2024 8:56pm
Fifth Horseman
If the oil level sensor works with a voltage applied directly to it then finding the fault should be relatively simple - there will likely be a fault in the wiring between the engine bay fuse box and the sensor. With the aid of the wiring diagram and a test meter any competent auto-electrician should be able to find the fault. There is a connector C11 (I think near the fuel filter) that the 12v feed to the sensor goes through on a grey/yellow wire on pin 10, which is a good place to test to narrow down the fault location.
Post #688724 22nd Mar 2024 1:07pm
