Home > Technical (L405) > Fault codes |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 141 |
When was the main battery last changed? If over 4 years then you are probably in need of a higher voltage battery. |
18th Mar 2024 9:35pm |
Chilcote Member Since: 10 Jan 2024 Location: Wells Posts: 2 |
Battery is less than two years old. Supplied by the local LR dealer. |
18th Mar 2024 9:59pm |
Best to check the battery voltage and charging voltage anyway. Maybe you have done a lot of short journeys recently? Or your alternator is poorly? Or the battery is tired although that is unlikely after only 2 years.
18th Mar 2024 10:24pm |
