![]() | Home > Technical (L322) > GAP IID Tool // Suspension Calibration |
Gap Technical support are pretty quick to reply so try them. I find you need to go into the height adjust function for the system to update a new calibration. 2012 TDV8 Vogue (L322) |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 290 ![]() ![]() ![]() |
I had this issue; there is a maximum range of tolerance on the suspension adjustment. If one of the height sensors exceeds the range then the adjustment won’t be excepted by the control module and the heights remain as they were. A temporary work around is to set all the corners so that they are “even” but 10mm lower than specified. That way the car sits properly but rides a little lower than spec. ( here even = what is specified for the front & rear heights minus 10mm )
vektory Member Since: 27 Feb 2023 Location: Vienna Posts: 21 ![]() ![]() ![]() |
Thank you very much for your inputs!
Here’s what was fitted to mine:
garth@internet.is Member Since: 12 Sep 2011 Location: Reykjavik Posts: 4 ![]() ![]() ![]() |
I cann't remember where or when I read this, that if you changed the calibration values, that when you reread them you get the previous values.
