![]() | Home > Maintenance & Mods (L322) > Swapping steering wheels. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7849 ![]() ![]() ![]() |
Yes, should be a straight swap for the bare wheel, though as you say, you will need all other items staying with the respective car… buttons, airbag, heated steering wheel loom and control module. Leave the battery disconnected just to be sure airbag wise. Don’t connect the battery again until all the electrics are back or it will throw loads of errors.
Earlier car but might be useful…
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
As said above. Keep everything with the relevant vehicle. You'll potentially have different can-bus for the different switchgear |
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 674 ![]() ![]() ![]() |
Thanks guys, hopefully I can get that all swapped over the weekend then get mine up for sale. |
