![]() | Home > Maintenance & Mods (L322) > a Wheel alignment and what to do L322 |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 215 ![]() ![]() ![]() |
Best to get a four wheel alignment done at somewhere that uses Hunter equipment. |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 281 ![]() ![]() ![]() |
I agree with the recommendation for a Hunter alignment. I guess you may have to travel a fair way to find one in Ireland though.
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 696 ![]() ![]() ![]() |
3 degrees is probably less than 1 spline on the steering column.
Fla Member Since: 26 Nov 2023 Location: South west Posts: 189 ![]() ![]() ![]() |
Hi all
Well worth making sure all suspension joints, bushes etc are in good condition before you do a wheel alignment as worn bushes will not keep the same alignment during dynamic conditions ( driving) as during static conditions ( alignments) and you can end up going round in circles esp with regards to off center steering wheels or pulling to one side. 2012 TDV8 Vogue (L322) |
Sorry double post 2012 TDV8 Vogue (L322) |
Hi Jaydee
Any good 4 wheel alignment place will do. Hunter are good but they are not the only ones. What tyres do you have? Brake pulsing can be a sticky piston on the front caliper which can warp a disk.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3242 ![]() ![]() ![]() |
If everything else is fine and the steering wheel is out of aliggnment, which can be annoying, you can reposition it. The initial stage can be a bit of a fiddle to release the mechanism but otherwise straightforward.
@ Jaydee
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 616 ![]() ![]() ![]() |
Hi, I'd be wary about just realigning the steering wheel because if it's not been set up correctly wrt the rack itself then the rack will not be central.
Hi Andy,
Be sure to check that it is put in tight tolerance mode if you go for a Hunter alignment. John
Weegie
