Home > Technical (L322) > L322 2011 4.4 - Turbo Boost Pipe |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 276 |
You’ll probably need to do a little more homework to get the advice you’re looking for; track down the specific part at fault and then use search on here to find what others have done.
10th Mar 2024 10:11pm |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 564 |
Hi, nothing to do with your question but I do like your wheels, those 5 spokes really suit the car, at least from that angle.
10th Mar 2024 10:45pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1469 |
You'll need to determine which of the boost pipes on that side it is. Here's the diagram to confirm:
11th Mar 2024 7:57am |
Fiorano575 Member Since: 28 Nov 2023 Location: High Wycombe Posts: 16 |
Thanks a bunch for that. I am currently in Italy so will take it down to a garage to inspect. |
11th Mar 2024 8:27am |
I am pretty sure they are from an X5. Even though the bolt pattern is the same, I was almost certain that I would need spigot rings but they mounted perfectly. They are Alessio rims. |
11th Mar 2024 8:31am |
Thanks a bunch for the excellent information |
11th Mar 2024 8:32am |
Thanks for that info. I did check his video out a few weeks ago and am seriously thinking about doing a EGR & DPF delete and mapping them out. |
11th Mar 2024 8:35am |
Thanks for the tip on the wheels, I'll look around.
11th Mar 2024 8:55am |
It took me a while but I got them in the end.
11th Mar 2024 8:59am |
