![]() | Home > Technical (L322) > White smoke and leak |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 852 ![]() ![]() ![]() |
Excessive amounts of white smoke could indicate head gasket failure on the M62 engine, I had it on mine and was lucky that no harm was done, quickly replaced with new gaskets and a full service at the same time, this was back in March 2022 with 169k miles on the ODO |
Jimmy86 Member Since: 27 Feb 2024 Location: East midlands Posts: 15 ![]() ![]() |
Thanks. Hoping that's not the case as seems too much of a coincidence that it started just after the work. I was wondering of the rocker gaskets haven't been seated properly. Can this cause the same issues? |
do you have any bubbling in the radiator and or coolant reservoir ?
Doesn't look milky, to be honest I cam not sure what it it. Initially thought it was oil but doesn't seem to be leaving marks on the driveway where is has been leaking.
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 358 ![]() ![]() ![]() |
It could be oil from the service burning off? Is it definitely leaking? How many miles since the service? Leaking from rockers could cause the white smoke - I’ve experienced it - but you’d normally smell the oil as well, burning on the manifold. |
And if you need to use the car just keep a close eye on the temps and oil level. And carry coolant and oil with you just in case! That’s what I would do. And drive like miss daisy. 😉 |
Thanks. Fortunately, have another car I can use so the RR can wait until the mechanic has a chance to have a look.
It wouldn’t surprise me, they seem to be tricky to seal on V8’s. I did the gaskets on a petrol v8 and one side sealed great and the other still leaks - I’ve lived with it for a couple of years as it’s not too bad.
Ta. That's what I'm leaning towards. Ironically, I think trying to replace the gaskets has made things worse. |
