![]() | Home > Technical (L322) > Correct Operation of Air suspension when parked 2011 TDV8 4 |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 780 ![]() ![]() ![]() |
You have a leak - most likely a pinhole in one of the front airbags.
Fla Member Since: 26 Nov 2023 Location: South west Posts: 190 ![]() ![]() ![]() |
Jookul
Jookul Member Since: 28 Dec 2020 Location: Munster Posts: 10 ![]() ![]() |
Hi
As I see
The operation of the suspension system is explained in detail in the workshop manual which you can download from the Wiki section of this site. The behaviour you describe can happed due to an air leak or a faulty height sensor. The easiest way to isolate this is to pull the suspension ECU fuse after you shut down and see what the car does i.e a drop on one corner is a pretty good indication of a leak in that area - bag or pipework. 2012 TDV8 Vogue (L322) |
Thanks all for the help.
I pass through mallow 6 times a week as I head to the City and all over Cork and Kerry for my job so its no bother to meet up with you when you have the work done.
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 504 ![]() ![]() ![]() |
hi
will308f
no not at all yea the same front drivers wheel well and rear drivers side wheel well ,what i did also was replace the voss connectors .valve block kit was about £18 from 4x4airseals and the voss connectors from island4x4 for about £7-8 each ,you do get the rubber seals for the voss connectors in with the valve kit but i replaced them and not a any issue with the front or rear dropping overnight like i was getting. |
Hi Guys
So Guys...
If it's not leaking then it's very likley to be a faulty height sensor or calibration drift due to wear of suspension parts. You would be wise to invest in a GAP IID tool...... 2012 TDV8 Vogue (L322) |
