![]() | Home > Maintenance & Mods (L322) > Windscreen Washer Pump Access |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7849 ![]() ![]() ![]() |
Can you get to the washer pump without taking the wheel off etc?
Thanks. Not looked to be honest as might have wrongly assumed not that as the rear works… are the 3 pumps on separate fuses?
Fuse 38 then… thanks for the info… teach me not to assume things 🤣
Might have to leave till later… the diagram doesn’t seem to match what’s there and the old fuses I have are much bigger 🤣… I know it’s a blue 15 amp, but could be any one… and I’m sure there are spare fuses there…..
Rotate the schematic 90 deg counter clockwise 2012 TDV8 Vogue (L322) |
🤣 ah, I see….. got it now…. It’s not the fuse….
Does the rear wash and headlight wash work? 2012 TDV8 Vogue (L322) |
The rear still works. Not tried the headlights. I understand you can swap connector and pipes to other pump as temp measure but if I’ve got to take wheel off I’d rather just do that and replace it. That said, I know it’s not ruled out everything beforehand. Looks like there are a few different pumps but I recon it’s DMC500040 from the diagram below….
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 330 ![]() ![]() |
Hi Mike
Thanks. I ordered DMC500040, which I guessed was correct looking at the below. Less than £10 from John Craddock… hope that’s the right one then.
Just fixed this. Managed to get enough access with the car in off road height. On mine the front washer pump was the far right one, the front any rear washer pumps are the same, as already mentioned above.
