Home > Technical (L405) > Health check video advice
caymanblack
This is my health check video from last year where two oil leaks were reported.
As i,m having a problem getting these resolved with the dealer I wanted to ask on here.
That oil level sensor leak is from the wiring harness that has been modified(oil in the plug)does this need the wiring harness replaced again?
The first small leak near what he says is the turbo what is required here? It cant be bad as I have no oil on the under tray.
Near on impossible to find out from this bloody dealer. Thx.
https://video.citnow.com/vtPWpmQjf40 overfinch modified
Post #687128 4th Mar 2024 11:25am
Gremlin500
@Caymanblack:
I assume you’ve seen this thread?
https://www.fullfatrr.com/forum/topic57501...ensor+leak
Yes, replacement of the sensor & loom required, but is it the original faulty type?
For the other small leak, why not purchase a cheap phone mounted endoscope camera, and try to investigate yourself where it’s coming from? Could just be sloppy oil filling, filter housing o-ring, or a multitude of other far worse possibilities.
Last year? Shocked “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #687133 4th Mar 2024 12:30pm
caymanblack
Thanks Gremlin . Yes this is from last year , so its in again very soon so trying to get the dealer to sort these things at the same time. Not easy I,m sorry to say.
Yes seen that thread and i,m trying to get the dealer to order and replace the harness. overfinch modified
Post #687136 4th Mar 2024 12:33pm
