![]() | Home > Technical (L405) > L405 Heated Windscreen |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 359 ![]() ![]() ![]() |
I can’t help unfortunately but I’m interested in this too as mine doesn’t work at all.. |
RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 222 ![]() ![]() ![]() |
If ot does not work at all, the other option is that the heated screen relay has failed. This is also shown on the photos. I took mine out to see if there any signs of anything odd and the put it back. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
Thanks I’ll check it |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
You can remove the A pillar trims in seconds. This is where the terminals are for the heated screen. I'd check for broken/loose contacts or a damaged ribbon. 2015 Range Rover Autobiography 4.4 SDV8 |
Both A pillars? 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
Check the side that isn't working. A multimeter may also help. 2015 Range Rover Autobiography 4.4 SDV8 |
I took the cover off today and all seemed ok except a redundant blue and white wire/connector. There did not seem to be anything to which it should be connected. See photo.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35486 ![]() ![]() |
there are 2 plugs there..one is for the screen which is live and the other is an optional for the wiper defrost. that one has no power
