![]() | Home > Maintenance & Mods (L322) > Restricted Performance AND Suspension Fault? |
Paul H Member Since: 17 Oct 2023 Location: coventry Posts: 79 ![]() ![]() ![]() |
Without the codes being read could be anything. Air suspension failing? I have an intermittent restricted performance for water in fuel ( again you need the codes read to identify this as just gives a restricted performance yellow warning symbol) You can get a cheap reader to identify faults or the gap IID that lets you do so much more. 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea! |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 221 ![]() ![]() ![]() |
First thing is to get the codes read. And if you haven’t already, get yourself an IID tool. |
ppceuro Member Since: 26 Feb 2022 Location: Derbyshire Posts: 9 ![]() ![]() ![]() |
Sorry yes- should've done this before.
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 195 ![]() ![]() ![]() |
You might want to check the front wiring to the suspension uprights and the hoses to the intercooler, a rip in these will give these errors, looking at the codes the intercooler hoses would be a good starting point.
Thanks Will.
Hi Nick,
Thanks a lot Will! I'll give this a try and revert back when I can! Appreciated. Nick R
