![]() | Home > Wheels & Tyres > 275/45 R22 on 2018 SDV8? |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3767 ![]() ![]() |
I have successfully run 285/50/20 which are nominally 792mm in diameter on the tyre calculator - however mine were larger All Terrains at 800mm - I measured them and different makes vary.
Just thought - the 285/40/22 are on offer at some tyre depots at the moment and ironically they are cheaper that the 21” versions at £995 for a set of four 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Jorrocks Member Since: 13 Feb 2012 Location: Shropshire Posts: 55 ![]() ![]() ![]() |
Vogue, thank you for taking the time to respond. I too was going to go to the 275/45 21’s until I realised the turbine wheels I have aren’t available in 21”.
I’ve had 4 sets of Grabbers on Range Rovers and 1 set of the Cooper AT3’s - I would quite happily have either and couldn’t tell any difference off road - I didn’t get stuck once with either - several friends did though in Discovery 4’s,5’s and RR’s on standard OEM tyres.
This might help re assessing if the 275/45/22 will fit as they are the same diameter :-
