Home > Maintenance & Mods (L322) > Rear subframe refurbishment
Wiltshire130
United Kingdom 2018 Range Rover Autobiography 5.0 SC V8 Corris Grey
As the rear subframe needed a full set of bushes and all brake components renewing I decided the easiest way would be to do it all off the car and in the relative comfort of the garage. Still cold but at least standing up and not on the floor.
Removal was relatively straightforward subject to a few provisos. Remember to have the handbrake off before disconnecting everything - makes getting the rear discs off much easier. Try and pick a day when the temperature is above freezing to do the strip down - all the plastic clips snapped (altough they probably would have done any way as they all seem to be designed to be fitted but never removed)
Stripped everything and took metalwork to be blasted and powdercoated
Back from powder coating
Main bushes fitted, diff mounting bushes fitted and diff installed. Then fitted on to 4 legs welded to top of my welding bench. Diff was chipped of all surface rust, wirebrushed and painted.
All built up and ready to be installed
Fixture for lifting
Vehicle high enough to allow easy removal and refit
Lifting back in
Finished - nearly. All brake lines front to rear replaced. All brake flexi hoses replaced. Rear ones were in an appalling state. Front bakes refurbished (cleaned up, titanium bleed nipples fitted, new discs and pads). EPB bedding in procedure completed and then off for MOT. Passed - no advisories.
I am fortunate to have a lathe and material to make the various bush removal tools. All bushes were genuine Land Rover.
If anyone wants more info on how it was done I am happy to assist.
If anyone in the south west is thinking of doing the same I am happy to pass on the tooling I made - I do not intend to do it again! L405 2018 5.0 S/C
Post #686641 27th Feb 2024 10:22pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Very impressive Bow down Bow down
Post #686645 27th Feb 2024 11:15pm
kevinp
Very good indeed. Thumbs Up
Post #686647 27th Feb 2024 11:36pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Good job Thumbs Up
Post #686715 28th Feb 2024 8:56pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Excellent job ! TDV8 4.4 2012
Post #686731 28th Feb 2024 10:53pm
mgrover
how easy was it to drop the subframe? did anything like exhausts etc etc get in the way?
i am planning to basically replace all the bushes in the rear so would be handy if i could drop the subframe entirely.
mainly worried about weight and having to faff with exhaust. Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #686788 29th Feb 2024 3:41pm
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
The exhaust has to be removed to drop the subframe. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #686790 29th Feb 2024 3:47pm
Wiltshire130
https://shop.normagroup.com/de_en/norma-euro-coupler-0367.html
My exhuast had already been cut and sleeved where it splays before reaching the back box. The sleeves used were the type in the above web link (I cannot get it to upload the image) . The back box itself is reasonably manageable balanced on a trolley jack and supported by a willing partner!
This saves disconnecting all the sensors and splitting what looked like fairly fragile flanges.
Slackening (but not completely disconnecting) the exhaust hanger halfway down the RH chassis rail allowed the exhaust to drop sufficiently to allow access. L405 2018 5.0 S/C
Post #686802 29th Feb 2024 6:25pm
Wiltshire130
The fairly simple to construct wooden support pictured in the original posting shows how I supported the weight of the subframe.
The rear section tothe subframe is flat at the bottom and the V is for the diff input flange to sit in.
Bolted to the jack platform at halfway between front and rear mounts which I assumed would be the point of balance and all came down staight and level in a controlled fashion. L405 2018 5.0 S/C
Post #686803 29th Feb 2024 6:32pm
plees23
Quality job youve done there!
Post #686894 1st Mar 2024 2:56pm
jamiej
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Solid effort!
Not sure many of us would trust all four jacking points in the same way you have. Kudos to you.
Post #686896 1st Mar 2024 4:08pm
D3Jon
That's a thing of beauty! Thumbs Up 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #686916 1st Mar 2024 7:24pm
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
Brilliant Thumbs Up
Post #686953 2nd Mar 2024 12:24pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
What a cracking job you have done! Thumbs Up
Jim
Post #686960 2nd Mar 2024 2:18pm
Mark_O
United Kingdom 2010 Range Rover Vogue TDV8 Santorini Black
This is awesome, fantastic to see.
I am looking at doing the same in the summer, was going to buy an eBay one to start on now, but happy for it to be off the road for a little while.
What was your budget for this?
How did you manage to jack the car so high, are they wooden extensions on the jack stands, trying to make out the pic.
Thanks for sharing.
Post #687105 4th Mar 2024 12:05am
