![]() | Home > In Car Electronics (L322) > The classic L322 lower-front HK speaker issue |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Yes, the old part has been superceded by that part number. You can actually change the speaker without needing to remove the full door card - just pop the bottom clips out and the door card will lever enough to get a T20 screwdriver in there to swap the speaker over.
rryan Member Since: 17 Feb 2024 Location: New Forest Posts: 33 ![]() ![]() ![]() |
Perfect, cheers Gary. The fact it’s so easy to get it out, I’ll check my part no to see what I’m working with. I didn’t fancy taking the whole door card off just to see which I had!
Yes it's interchangeable - in terms of specifications, the parts are exactly the same.
Very good point. Thanks for your help on that one, much appreciated. |
Paul H Member Since: 17 Oct 2023 Location: coventry Posts: 72 ![]() ![]() ![]() |
Just be aware that the 420 and 430 look almost identical but have different connections ( guess who forgot to check before ordering!), I got mine direct from jaguarlandroverclassic.com and they really are a doddle to fit, 15 minutes max, there is a good YouTube video on it that is worth a watch [/url]https://www.youtube.com/watch?v=Ws2soh_6KX0&t=262s [/url] 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea! |
