![]() | Home > Technical (L322) > How Do I Know If Active Damping Is Working ? |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 655 ![]() ![]() ![]() |
Hi,
Hi JayGee, OK, I'll give that a go, so it defaults to hard, thanks
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7905 ![]() ![]() ![]() |
As above…. Oh yes, it’s disabled then 🤣 made me feel sick and that was on a dual carriageway 🤣 2011 Range Rover Vogue SE 4.4 TDV8
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3817 ![]() ![]() ![]() |
You also loose special programs function , from memory ?
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 100 ![]() ![]() ![]() |
If it's not working it'll feel like driving a series leafer suspension wise , wire snapped on mine a few years ago on top of A66 (you also get a warning on dash) 120 miles towing a tonne and half of caravan to Scotland and you know about it , make you feel sick and rattles your fillings out , set up caravan , remove top of strut and twist wires together , sorted till holiday over and can fix it properly at home .(had tools for MTB so torx bits with me ) |
