Home > Technical (L405) > P041C DTC |
Ryanmt Member Since: 14 May 2015 Location: Warrington Posts: 71 |
https://www.fullfatrr.com/forum/topic50202.html
26th Feb 2024 1:42pm |
Captain_67 Member Since: 26 Feb 2024 Location: Ellesmere Posts: 14 |
Thank you for your reply Ryanmt
26th Feb 2024 3:56pm |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 221 |
You'll likely need the Telematics unit told the battery has been replaced see topic here |
26th Feb 2024 6:31pm |
Thank for the info fifth. I’m glad I read your advised post as I thought the telemetry unit was in the rear quarter panel! |
26th Feb 2024 7:48pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1194 |
P041C Exhaust Gas recirculation temperature sensor B low means resistance is low and probably shorted, check wiring for damage/scuffing/connections etc and resistance of sensor soak threads well with WD40 etc
26th Feb 2024 9:03pm |
Thank you KOT, I couldnt ask for any more than that, I should be able to confirm its the sensor and replace it. Looks like it is reasonably easy to access once the plenum is removed although that may prove to be wishful thinking! |
27th Feb 2024 8:18am |
Hi KOT,
28th Feb 2024 12:32pm |
Good news, can you not unplug sensor and measure resistance of sensor with a meter ? 2018 SE SDV8 4.4 Byron Blue |
28th Feb 2024 12:48pm |
Hi KOT,
28th Feb 2024 3:34pm |
28th Feb 2024 6:56pm |
