![]() | Home > Technical (L460) > Headlight Condensation |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
They will tell you it is normal and nothing to worry about (see ownerinfo.landrover.com, Exterior Lights). My L405 lights have condensation regularly in colder weather and that is what LR said when I complained, the manual/ownerinfo says much the same as that of the L460, subject to the L460 one adding that it's worse with LEDs as they don't generate much heat. Only Range Rovers since 1988 |
5.0 Member Since: 25 Feb 2012 Location: Surrey Posts: 718 ![]() ![]() |
Mine are like that too in cold weather. My L405 was the same and I had those replaced under warranty but the replacements were just the same. If it comes and goes I don’t think it’s much of a problem. If it’s constantly there and all over the glass then it ought to be replaced. It only seems to be along the bottom, DRL area of mine. |
TST717 Member Since: 18 Oct 2014 Location: Inverness Posts: 35 ![]() ![]() |
I have had this same problem with a Cayenne I have had since new.
NavinIyapah Member Since: 13 Nov 2023 Location: London Posts: 11 ![]() ![]() |
I’ve had exactly the same problem with mine. My car is currently in the garage at the moment to resolve a few other minor warranty issues. Ill let you know how it fares when I get the car back |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 791 ![]() ![]() ![]() |
Update. Took a while but after a conversation with the dealer principal (manager) last week, it’s been confirmed that both headlights are going to replaced. Result! MY23 D350 HSE
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35627 ![]() ![]() |
Phil, did you ask the dealer why this is happening .. ... - .- -.
JackRegan Member Since: 20 Oct 2012 Location: Wirral Posts: 243 ![]() ![]() |
Nice one Phil |
Yes Stan. Apparently ‘they all do it’ was their initial response and they showed me several examples of L405’s and L460’s on their forecourt! Not good for supposedly ‘sealed units’.
kinda valid explanation i suppose.. |
tomo141 Member Since: 22 Aug 2017 Location: UK Posts: 91 ![]() ![]() |
It's interesting that they told you the LED's runs cooler, as they have fans to keep them cool.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1666 ![]() ![]() ![]() |
Firstly, I have to say I’m not familiar specifically with the L460 headlights, having an L405 myself, but speaking generally about “water in lights” syndrome: (both tail lights and headlights).
