Home > Off Topic > WTF is this?
Huwrhys
United Kingdom 2017 Range Rover Autobiography SDV8 Loire Blue
WTF is this?
These are to be found on quite a few telegraph poles in the Hornchurch area. Some also have a dome thing wired in to it.
Any ideas what they can be and should I be removing them?
Post #686433 25th Feb 2024 3:26pm
dingg1
If you own the pole I suppose you could remove it...
If the pole belongs to someone else, wind your Censored neck in.
Fibre Internet?
Post #686446 25th Feb 2024 5:38pm
Full-fat-Lance
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Orkney Grey
As above, they’re for fibre internet
Post #686447 25th Feb 2024 5:56pm
Huwrhys
I was joking about removing them of course, no neck winding required. I wondered if it was something to do with ULEZ or pay per mile.
Post #686448 25th Feb 2024 5:58pm
andygts
It's beyond me why they are still bothering trying to get wired broadband to residential properties, 5g mobile networks are fast enough for 99% of of households.
The government should focus their efforts on getting full UK mobile coverage. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #686573 27th Feb 2024 10:33am
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
Unfortunately, if the government (not that it's their problem since 5G is privately owned infrastructure) were to put time/effort/cash into getting coverage into every home, the usage of millions of households concurrently would saturate the available coverage and reduce its usefulness to zero without a lot more infrastructure in place.
You only have to watch the effect of a football match, concert, festival, or whatever on the speed and reliability of a 5G connection, even in major towns and cities with excellent coverage, to see what'd happen.
As a country, we'd need tens of thousands more cells than we have at present to provide sufficient bandwidth for every home to use 5G connectivity as their source of broadband connectivity. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #686581 27th Feb 2024 11:14am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi, 5G is generally only confined to high density population areas because it's relatively low range and building penetration is poor. The further you go from the mast the more "noise" is created and the atmosphere, any anything in between, also reduces the signal strength and thus the amount of data able to reach you reliably.
Higher frequencies give the opportunity for higher bandwidth, however, that's shared amongst all users, so your phone may well be showing that your in 5G mode, but if there are a dozen of you using the same tower then you'll sharing that and so you could well be running at 3G speeds or lower.
Lower frequencies give much higher range and better penetration, but support less bandwidth. So the likes of aircraft, ships & subs tend to have VLF systems for essential comms, whereas city mobiles can reach almost microwave frequencies.
Consider it like water in a leaky pipe, the further you are away from the tap the less pressure you get, the more leaks (higher bandwidth) you have the less distance the pipe can be to get water to the end. The more people using the same pipe, the less water there is available to you. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #686586 27th Feb 2024 11:50am
AndyRoo
Hi, forgot to add, a 5G cell is about a mile in diameter at the edge, anything closer to the mast can run faster, the closer to the edge, or beyond you just not going to get 5G speeds.
It will never be economically viable to get 100% nationwide coverage for 5G, there simply isn't the traffic in rural areas to support the business case for a mast there.
The big providers only give 99% coverage predictions, and that's population reachable by mobile not geographical area, that is about 85% coverage and that's not 5G speeds either. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #686588 27th Feb 2024 11:55am
AndyRoo
Everything you never thought about regarding celular radio and mobile signal propogation.
https://dgtlinfra.com/cell-tower-range-how-far-reach/ Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #686589 27th Feb 2024 11:58am
Fla
Ireland 2012 Range Rover Westminster 4.4 V8 Zambezi Silver
In my time as a tech I installed around 4000, fibre lines, pstn lines, fibre to the cabinet and anything else that was available. In Ireland we are spending 3 billion euro to get fibre to most homes and then wireless where it is unattainable. The beauty about fibre over wireless is it can be upgraded quite easily with minimal interruption, in other words, for most 150mb will do but if you want a gigabit its there, using the same lines they can increased that over time to 2 gig etc with minimal infrastructure upgrades.
In my house I'm using a P2P internet provider. I get 50 down and 10 up which considering where I am is great. In 2 years we will have FTTH and for things like CCTV, High def streaming, gaming etc that will be a game changer. Though the wireless does us fine, its limited. I cannot upload 10 cameras, have a home office, have streaming etc without something giving up.
Wireless is definitely a solution for 10-20% but for the masses you cannot beat the reliability and uptime of well terminated fibre. Current yokes
Subaru Sambar Pickup Tipper
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #686594 27th Feb 2024 1:01pm
AndyRoo
I just posted the latest from Starlink, it's not going to give you such high data rates, but once you park up and pitch the antenna, you're away, anywhere.
Not cheap, but I was wondiering if anyone has tried it in the real world of offroading.
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #686608 27th Feb 2024 2:24pm
