Headlights after new windscreen | |
A short while ago I had to have the windscreen replaced so out came autoglass. Sadly insurance wouldn’t pay for pilkington so I got whatever cheap bit of glass was provided.
I soon noticed after it was changed that the headlights were coming on a lot more often, including when you really wouldn’t expect eg bright sunlight. It seemed quite random though as sometimes the lights behaved as expected. Wipers were unaffected.
So out came autoglass again (same person!) and before trying to change the glass they changed the sticky gel pad that holds the sensor in place. It had been replaced when the screen was done the first time but they replaced it anyway. Sure enough, that didn’t make any difference so he got on the phone to the technical team.
After 5 minutes or so on hold, they told him to try turning the ignition on, switching the lights to off, turning off the ignition and then locking up the car and leaving it for 5 minutes. Then once the time was up, ignition on, lights to auto and that should perform some sort of recalibration.
I was sceptical but it did actually work and for the last few weeks since doing that the headlights have behaved as expected. As it wasn’t a solution I had found on here, I thought I would post in case it helps out anyone else. Car is a L322 2010 4.4 TDV8 Autobiography.
