Home > Maintenance & Mods (L322) > Heater control removal for bulb change,
Keefy Dunster
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Good day all,
can someone point me in the direction on how to remove the heater control panel to replace the bulbs behind it ,the controls that control the temperature, i dare say this has been covered before but i didn't have much luck using the sites search engine , also is it worth replacing these bulbs with LED's an if so which ones ,thank you, 200604,2 supercharged Very Happy
Post #686293 23rd Feb 2024 3:12pm
garyRR
I stand to be corrected, however when I had one apart once (which I think was from 2006), it was LEDs, not incandescent bulbs.
A PCB repair specialist can change the LEDs for you though, but it will likely be cheaper to buy a new panel on ebay. 2015 Range Rover Autobiography 4.4 SDV8
Post #686314 23rd Feb 2024 8:27pm
Keefy Dunster
many thanks for your feedback sir, will have a look for a new/second hand panel .
Post #686338 24th Feb 2024 11:18am
