Home > Range Rover P38 > NEW PROJECT ISSUES! |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 115 |
I would plug into the diagnostics and get some live data. Check all the sensors for 'sane' readings, particularly temperature sensors.
20th Feb 2024 6:17pm |
AnotherMutley Member Since: 16 Jan 2017 Location: Kent Posts: 400 |
Wasn't one of things on the P38 diesel that the fuel lines went porous over time, memory is not as sharp as it used be? |
21st Feb 2024 2:48pm |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 |
One of the common BMW diesel engine issues affecting that engine and other variants (not just in the L322) was degradation of the o-rings in the fuel system allowing fuel to leak back to the tank over time and/or prevent rail pressure building up quickly enough (or at all) to allow starting under certain conditions. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
21st Feb 2024 3:04pm |
