![]() | Home > Technical (L405) > Vibration concern - is it me? |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3756 ![]() ![]() |
Have you got noise reduction tyres ? If there has been a puncture the tyre depot removes part of the foam and sticks it back - this can come loose causing vibration, or a buckled wheel, lost wheel weight or a drive shaft bearing on the way out. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1391 ![]() ![]() ![]() |
If it's happening at idle then probably not tyres. Maybe engine mounts? Only Range Rovers since 1988 |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 771 ![]() ![]() ![]() |
Agreed. Could be the active engine mounts. Kev
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1571 ![]() ![]() ![]() |
#3
Of course they can be tested. They are vacuum controlled so you can apply a vacuum and see if it holds.
Or here...
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
Many thanks for your replies
JamboM3 Member Since: 28 Jul 2021 Location: Berkshire Posts: 204 ![]() ![]() ![]() |
Related possibly but I found my L322 to be quite vibration-y at idle and generally unrefined. (4.4tdv8)
