Home > Maintenance & Mods (L405) > Lower Arms MY17 L405 SDV8
JamboM3
What brands (aftermarket) have people used to replace their lower arms?
I usually go with lemforder but they are practically the same cost as gen LR parts!
Not used Delphi for suspension parts but used other components that were fine, so thinking of going this way.
Any other recommendations?
Post #685734 15th Feb 2024 11:04pm
Gremlin500
I just ordered the Febi Bilstein ones from Advanced Factors with the FFRR Forum discount, these are the parts you need:
LR148059 1 off Front RH Lower Control Arm
LR148060 1 off Front LH Lower Control Arm
LR097372 2 off Bolt
LR038365 2 off nut
LR034221 2 off nut
Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #685744 16th Feb 2024 7:34am
JamboM3
Didn't see the Febi when I checked before, just looked and they are good value! Thanks.
WIll do the Front/rear ones also as I suspect this is the source of the knocking noise I have acquired.
Post #685794 16th Feb 2024 8:02pm
Gremlin500
@JamboM3:
I suppose you read this thread? Just thought it might be useful to you if you don’t have the tool yet:
https://www.fullfatrr.com/forum/topic67045.html
Post #685806 16th Feb 2024 10:42pm
JamboM3
Thanks.
I won’t be swapping them but will be useful for my mechanic!
Post #685810 16th Feb 2024 11:19pm
